z-wave.me Wallswitch and Fibaro 2x1.5 relay
Hi all,
I have a z-wave.me wall switch (battery operated, single paddle) directly associated with 2 Fibaro 2x1,5 relays.
The switch works fine, however I cannot assign only S1 or S2 of each relay to the switch, which means s1 and s1 are always switched in both of the relays.
Is that a known bug, or am I just missing something?
cheers
joystick
BTW. I am running the latest HC2 stable firmware.  The Wall controller is: z-wave.me 05443
    ok, so I did not get that much response, I assume maybe noone has the same problem?
    however, I was trying to do something more complicated: Scene Activation.
    So I googled, and found out that I need to set two parameters (13 and 14 - 1d - value 3) to tell HC2 to get scene activation.
    I then copied some small code to see if the value is set correctly, but.... nothing.
    Maybe someone could give me an hint here?
    Thank you very much!
