Dimmer 2, toggle switch and remote ON
I have an strange situation when I use the dimmer 2 with toggle switch and remote (web page or mobile app).
I can turn ON/OFF correctly with toggle switch
I can turn ON/OFF correctly with remote
When I turn ON with remote and try OFF with toggle switch I need 2 clicks (return to initial switch position) to turn OFF.
This is normal?
7 answers to this question
    Any advice?
    I make more test (I have two toggle switch, one in S1 and other in S2):
    - Parameter 26 = 0: I can turn on/off remote and with S1 but S2 doens't work
    - Parameter 26 = 1: S1 and S2 works but if turn on with remote I need 2 clicks with S1 or S2
    Any help with this?
    I have two dimmers with the same situation.
    I use this wired connection:
    Source:
    I have the same problem here. When i try to control a associatitet device. If i use a scene it works on the first click.
    I suppose that with push button it works well ?
    I don't know, I have toggle switch.
    I recover this post because I have the solution... FIRMWARE UPDATE TO 2.8
    @Fibaro Support, it wasn't a problem of my wiring installation it was a problem of Dimmer 2 when you connect S1 & S2. 10 months to resolve this...
