Wake up dead nodes (multi device) + battery
I am looking for a way do wake up dead nodes. I have created a VD with 2 buttons. Each with this command:
fibaro:wakeUpDeadDevice(154);
Now, the problem is that one of the devices is a battery powered multidevice. Do I need to use the master device ID?
And second, is the command correct to wake up and connect the fibaro with the dead device?
7 answers to this question
I have found that this command doesn't work as expected, instead I'm using  fibaro:call(1, 'wakeUpAllDevices') function, which wakes up all dead devices at once.
In addition when using this function you don't need to worry about master or slave device.
If you have frequently dead devices, may I suggest to check automatically for dead devices every X minutes and if there are dead devices execute the function. (In my case the system sends an e-mail with the list of dead devices). I believe this is better solution rather then checking manually and pushing buttons....
If you have door sensors or other devices which are part of you alarm setup, it's necessary to wake up those devices automatically, otherwise your alarm won't work properly (especially during the night or in case of absence -  when it most needed)
    Thank you, I will try it with the new command. I have a scene that checks every hour.... does the wakeupall command slows down the z-wave network ?
    No, it does not slow down the network.
    BY the way I did it at Virtual device.... I have found that this way it more reliable. (sometimes there is an issue with scene triggering)
    Hi cag,
    Do you mind to share the code you use in virtual device? So it's working in HCL as well?
    Thanks!
    Sorry about the delay... here is the code.
    You cannot write LUA code at HCL, so it doesn't work with HCL.
    if you launch this scene I give me the error:
    [DEBUG] 07:53:50: [1;31m2015-11-14 07:53:50.929457 [ fatal] Runtime error: /usr/share/lua/5.2/json/decode.lua:74: bad argument #1 to 'match' (string expected, got nil)[0m
    What's wrong?
    Guest nohed
    I also get the same results
