Im using a FGD-212 to control the light in my bathroom sealing, in the same rack i got a FGS-222 for the mirror light.
The problem is that the FGD got triggered even when using the FGS. Eg. I'm using the switch for on/off and at the same time the light in the sealing goes on/off depending on the initial state.
Example: All dark, turning on the mirror light, turning on sealing light, turning of mirror light and the sealing light goes automatically off. The same happens when trying from the web or the app.
What can be wrong? Where should i look?
Any specifics to look for when it comes to the installation of the 2 devices? To secure that they are correctly installed.
Kristian
Seems like you are using a switched live as live for your sealing device? Can you turn on the sealing light when the mirror is off?
    Yes i can. After some more testing this seem to be the case.
    - if the sealing is off I can turn the mirror on/off wo any problems.
    - If the sealing is on I can still turn the mirror on but during that operation the sealing goes off for 2-3s and then turns automaticky On again.
    Jag har samma problem. Har du möjligtvis lysrör som spegelbelysning?
    Har du med dig en nolla ner i dosan eller är det två ledare med en dimmer bypass? Skicka upp en bild på hur inkopplingen ser ut så blir det enklare att klura på.
    Thanks! Will send picture. No I got spots in the mirror.
    Hi! Your FGD-212 probably switches off (or on) because a signal from the other device(s) interferes, through the wiring. As Joacim said, you are running a (switched) N in parallel with the S1. I can simulate this problem. Fibaro is working on this issue and should have a solution soon. To see if I am right, please send a mail to [email protected], tell me that I sent you
    /emoticons/default_icon_smile.gif" alt=":-)" /> to diagnose this and refer to this related topic:
    Thanks, mail sent to support.
