Please advice which of fibaro device should use
Hello! I recently bought two water flood sensors from fibaro and also installed:
MISOL Motorized Ball Valve, 220v, 2 way
so please advice which of fibaro devices i should use on motorized valve?
 or
Please advice!
Thanks!
 or
Please advice!
Thanks!
According to schematic of the Valve you have two options from outside - close or open. If this is correct you need to use fibaro double switch. Don't see any sense to use Roller Shutter.
By the way as I understand you need to use the switch very careful and not to be in situation when Valve's both control lines (red/green) will be connected to the ground simultaneously. (I think when they both are open, no harm done ).
Please make sure that only one control connected.
Another idea is to buy FORM C relay which could be controlled by fibaro switch, this will assure that only one line connected at the time.
Please see follow link at ebay... looks like the same model but cheaper
    this was the matter why i though will be an option to use roller shutter module to avoid this: "By the way as I understand you need to use the switch very careful and not to be in situation when Valve's both control lines (red/green) will be connected to the ground simultaneously"
    do you think roller shutter 2 will be working with this valve and will be able to calibrate like it is doing with a roller?
    Thanks!
    Thanks!
    To operate the Valve you need to switch the ground! The roller switches AC power-220V only and cannot be connected directly to the valve...
    The double switch is independent switch and can switch any signal connected to his "In". In your case the input should be connected to common  (black wire) ground of the valve. "Q2" and "Q1" should be connected to red and green wires (depends what valve's state you need when the switch is off).
    Again the roller on his outputs provides 220VAC, please be careful.
    Valve works on 220v also so why roller switch can't be connected to the valve?
    Because you need to switch the ground of the valve.  220V provided to the valve by yellow and blue wires,
    See the valve's diagram on amazon
    In other words it won't work with roller.
    but valve is working on 220v and roller shutter also on 220v
    so why voltage can be a problem in this case?
    You knowת let's do it other way... could you please post a drawing (connections) of how you're going to connect the valve to roller?
    by the way I took another look on diagram and there is AC-DC converter, so actually the motor works on DC and by connecting 220 V with roller it will blow up.
    Hope your system works.
    Goodbye
