Hi!
Anyone got wiring diagram for separate double switch connection (stair case) for the old/new dimmer?
Cant find it anywhere and are not in the manual.
Thanks!
Guest fat
Just remove the middle switch and that should be what you are after
    Thanks! Anything for the new dimmer ? Fgd-212
    I use this:
    But I have a issue with remote & toogle switch (I need two click to turn on or off the light)
    • 3 weeks later...
    I use this:
    Same with me - did you manage to solve the issue? I used wiring for 2 momentary switches with phase cable. N & Sx are connected together, switches are connected to S1.
    P.
    P.
    No, I don't have any solution.
    I don't think that this wiring is correct:
    Next I'll try to reconnect both switches to Sx - not L as shown on the diagram. That would make me move the dimmer between switch boxes, so it will take some time to do so.
    Hi patryk, I think youre right this wiring does miss the N connected to the Dimmer (N)
    Also the two switches are drawn in a wierd way - they are simply in parallel providing L to S1 whenever they are pressed.
    I do have such an installation with 5 switches and of course with N connected to Dimmer (N) and it works.
    As some people discussed here the FGD-212 seems to be quite sensitive to parasitic signals comming from long wires connected to S1 (or S2), putting an old fashioned solenoid (relais) inbetween eliminates this - but somewhat an unpleasant workaround.
    cheers,
    gruberb
