Please advice which of fibaro device should use
Hello! I recently bought two water flood sensors from fibaro and also installed:
MISOL Motorized Ball Valve, 220v, 2 way
so please advice which of fibaro devices i should use on motorized valve?
 or
Please advice!
Thanks!
Based on specification from amazon, 230v ac is required to operate this valve. I suppose that you will need one circuit to open the valve and second to close it. In this case, roller shutter is the only solution suitable for it.
Wiring diagram of valve would help more.
    Thanks for clarifying things for me!
