How to stop lights from turning on when sensor detects more then XXXlux
Hello! See attached pictures. There is screenshot with my scene. I'm new with fibaro. Can anyone advice how to do to have light turned on only when light sensor detects value under 500lux like example? Because now light is turned on all the time when sensor detects moving. Also i don't have option to have light turned off less then 1min after no movement is detected. Using magic scene is possible to do a scene if i want to have lights turned off after 30 seconds? Or please advice how to create scene if i use graphic blocks method.
Thanks!
see attached for what you are after:
motion detected and light level less than 500 lux then light will turn on for 30 secs
