entire 3 Share Posted October 27, 2015 Has anyone tried the new Qubino Flush Dimmer Plus yet? I have two, but they will not complete the configuration, they always say configuration failed. I have tried close to the HC2 and still the same. They can still be used and can be turned On and Off using the slider, and Off using the button but not On which is strange. Cheers Mike Quote Link to post Share on other sites
0 sjauquet 15 Share Posted October 27, 2015 dimmer PLUS ? Where did you get that ? Do you have the reference ? Because the ZMNHDA2 is not a new model Quote Link to post Share on other sites
0 entire 3 Author Share Posted October 27, 2015 dimmer PLUS ? Where did you get that ? Do you have the reference ? Because the ZMNHDA2 is not a new model Vesternet http://www.vesternet.com/z-wave-qubino-flush-dimmer-plus ZMNHDD2 came out on the 16th October Quote Link to post Share on other sites
0 sjauquet 15 Share Posted October 28, 2015 hmmm looks like it's just the autralia brazil and new zealand version... Quote Link to post Share on other sites
0 entire 3 Author Share Posted October 28, 2015 hmmm looks like it's just the autralia brazil and new zealand version... typo sorry, I have ZMNHDD1 which is Europe frequency Quote Link to post Share on other sites
0 sjauquet 15 Share Posted November 5, 2015 any news? did you manage to add it ? Quote Link to post Share on other sites
0 entire 3 Author Share Posted November 5, 2015 they are added but still marked as not configured. They work, but not fully as mentioned before Just need fibaro to look at why Quote Link to post Share on other sites
0 mgmidget 2 Share Posted November 6, 2015 Hello I have received the following response from FIBARO regarding ZMNHDD1 We are aware of That, this module is not fully compatible with Fibaro yet. Our Soft Developers are working on different devices of many different manufacturers to see if Fibaro Could be fully integrated with them. Please be patient as the functionality apr improved within the next software update. Quote Link to post Share on other sites
0 tommyjo 0 Share Posted November 21, 2015 I got 2 of the qubino ZMNHDD1 dimmers and can confirm that statement above. The 1st dimmer I installed showed up as double of everything, it was working for 2 days, then I lost contact with it. I just installed the 2nd today, adding it to HC2 worked after 3rd try but then it was not working at all. It showed up as 1x box, 2x dimmers and 2x motion sensors. All devices said "not configured" After 3 tries of adding and removing, I went back to my old elko dimmer and my wife asked whant I had been doing all day Quote Link to post Share on other sites
entire 3
Cheers
Mike
Link to post
8 answers to this question
