There is a bug, the slidebar accept float numbers on param 64 but the variable is integer.
You can try to se the range to 25.5. but the last set variable going to 255 (integer)
....It's impossible to set reports under 1° C (example 0.5°C)
There is an issue to set 0.5°C or 0.2°C, but you should be able to set 0.4°C, 0.3°C or 0.1°C and yes, the reports work accordingly. Didn't see any issue.
Dou you mean parameter 60?
I have that one set to 0.6º withour problems. See pic.
What version is your HC2 on?
Parameter 60
This parameter determines how much the temperature has to differ from the last value to be reported to the controller.
0 disables the reports.
0°C
25.5°C
0.6°C
    You can see te value on the right... but if you change and save new value the value you can see te effective temp is never with decimals. If you try to set from 0.1°c to 0.9°c  you'll see 1°C (see on my picture on bottom -> Last set value)
    There is a problem with the latest version 4.057, after saving the screen is not updates. Please do refresh to the screen and then you'll see correct last value.
