Is it possible in some way to shutdown HC2 ? I have info from UPS that battery is almost done, so I would like to shutdown HC2 in nice way.
8 answers to this question
i thought there was a script somewhere on this forum?
    I found script based on os.execute() which is no more available.
    Create a single button VD with this code, where 192.xxx.xxx.xxx is the ip address of your HC2.
    then create a scene to press the button, where the id of the vd is replaced by vd_id below:
    Finally, I use the scheduler written by robmac to schedule the reboot once a week.
    I found that, I just want to shutdown - in my small village sometimes I don't have power for few hours, so I need to shutdown HC2, not restart.
    I need that solution, too...
    Hmmm... get a UPS
    Hmmm... get a UPS
    great advice
    but what should I do when UPS will be discharged?
    To shutdown the HC2 gracefully you can use   HomeCenter.SystemService.shutdown();
    and for restart you can use  HomeCenter.SystemService.reboot();
    Requirements
    • Fibaro Home Center 2 updated to 4.081 software version or higher
    Edited by grimy112
