Is it possible to use a relay switch as an input only? I have a wall switch connected to S1 and a light connected to Q1. Everything works fine. When I toggle the wall switch (manually or in hc2), the light turns on.
Now I don't want this light to turn on when I toggle the wall switch. I want only to turn on another light (relay module) and the light connected to Q1 should stay off.
Many thanks!
connect the switch to s2
    If I connect it to S2, then the Q2 light turns on. Is there a way to disconnect the S with the Q?
    strange installation, you have two light connected at the module two switches and do not want the switch to activate the module...
    Looks like they have not been designed for that case
