erip-eri 0
I want to control my Ventilation System (Stork Comfofan in Basement [office and washing] and Brink Renovent in other parts of the house) using the 0-10v outputs of a RGBW controller.
Based on Netatmo Humidity, CO2 level and whether someone is in the shower or the washing machine is running I could set the fan speeds of these 2 devices. These fan speeds have a known corresponding power consumption, so when my output is 5v I know that the Brink uses 60 watt.
Is there a method (maybe virtual device) where I can calculate and set the power consumption over time based on the output of the RGBW. (Similar like the dimmer module does)?
thanks
Eric
