Help needed: Howto report a broken lamp when light is turned on.
Please help me.....
I tried to create a scene that checked the power consumption when a lamp was turned on (did this with a "block scene").
The idea was that normally the lamp (it has three LED blobs) consume about 30w when it is on, but if the power consumption was lower than 30w when the lamp was turned on then a mail should be sent to me telling me that one lamp is broken.
Got it working once, but then my HomeCenter2 started to act strange, other scenes stopped to work. Got the feeling that my new scene killed a lot of other scenes.
What I want is a scene that:
1. 10 seconds after that a lamp is turned on checks the power consumption
2. If the power consumption is lower than 23w then a mail should be sent to me.
3. I only want to do the check one time 10seconds after that the lamp is turned on, not a constant surveillance of the lamp (guess that it was this that my scene did)
Would prefer to do this in a LUA scene, but I am a beginner in LUA programming......
Thanks in advance!
5 answers to this question
Please help me.....
Thanks in advance!
Hi
This scene should work.
Create a variable, as in the picture, it should make it not run in the loop.
The variable, set to "on" when the light turns on and "off" when the light is turned off.
Here watt be below or equal to 3 watts in >15 seconds if the e-mail should be sent.
Hope it helps.
Hi
Hope it helps.
How can i create variable chcecked? Can you post screen or whatever
The variable is called "Light" and has three modes, "Checked", "on", "off".
See picture above.
Hope it helps.
See picture above.
Hope it helps.
Yes, but you must make scene for on, off and chcecked variable. And there is problem for me. I do not know how to do.
Hi
Has made a few small changes, this will hopefully work.
In schreen dump: Så = Then --- Og = And
First, create variables. There must be a scene for turning on the light, one to check the light and one to turn off the light.
Hope it will work.
