Foscam FI9900P
Anyone has managed to get this camera to work with the HC2?
Rui
8 answers to this question
No.
Moved the port to port 80, still no luck. Pity really, was looking good
Guest bulldogxxx
no mjpeg stream to setup for fibaro
Any news on the cam and HC2?
@zaanhoeve
Hi
 Did you connected the Fi9900P cam to the Fibaro Home Center ? What kind of plugin did you use  and  can you help me with de JPG and the MJPG stream path ?
Tibor
I do have a FI9900EP working in HC2. Using the strem URL out of this
I did set it up manually under Modules - Add Camera. Using the IP Adress and as type I've selected "IPCAM" (Did pick that up in some other community)
Cheers
Cheers
Could you please explain exactly how did you added the camera to Fibaro.
Thank you
@kerttll
I've choosen as type "IPCam"  and used the following link
For JPG&MJPEG
http://user:password@IPADRESS/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=USER&pwd=PASSWORD
you would have to adjust all the red colored things.
Wrong, thats the snapshoturl, not the mjpeg stream.
