Hi
Fibaros Yahoo Weather data has been very unstable (not because of unstable weather
/emoticons/default_icon_smile.gif" alt=":-)" />) approximately the last 5 days. Very inconvenient when I use it to heat control, only the temperature.
I have found out that the weather changes exactly once per minute eg -full sun 13 degrees-moon and some clouds 10 degrees-11 degrees fog and rain and 15 degrees and it stays. The shift is exactly when the second pointer is on the 12th
Is there anyone who has seen it, and what can you do about it.
    Hello Fibaro
    The prestigious app. on the tablet, was destroyed by.
    Here in Denmark the weather changes between: Full sun, moon, fog, rain, cloudy and more.
    Temperatures from 7 -16 degrees. All this can occur within 10-15 minutes and is updated every minute. Where is the error, can I do anything. The error was not a week ago.
    Fortunately, only Fibaros Yahoo Wether
    /emoticons/default_icon_question.gif" alt=":?:" />
    Yahoo app. on the tablet is fine.
    /emoticons/default_icon_exclaim.gif" alt=":!:" />
    Same problem here in France, a lot of person on french fibaro forum have the same problem... Fibaro integration of Yahoo meteo api is not working anymore since a few day.
    Same problem here in Russia...
    In Poland too ....
    Gosh! Didn't know all that! I have to admit... I live in Belgium and I don't need a weather app. The weather is always bad.
    /emoticons/default_icon_smile.gif" alt=":-)" /> :-)
    And of course, same for Sweden
    I guess it's a problem everywhere
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> Here in the Netherlands I have the same poblem.
    • 1 month later...
    How is the format that you should type in your city?
    I never had the weather working how much that i try different combinations.. Only city, only Long/lat, long/lat 4 digits, 6 digits, long/lat and city, city with big spelling, litle spelling etc etc..
    Should you type both Long, Lat and the city. Or is the long, lat being calculated from the city?
    How have do you have your settings?
    Hvordan er det format, som du bør skrive i din by?
    Jeg havde aldrig vejret arbejder, hvor meget, at jeg forsøger forskellige kombinationer .. eneste by, kun Long / bredde, lange / lat 4 cifre, 6 cifre, lange / lat og by, byen med store stavning, litle stavning osv osv ..
    Skulle du skriver både Lang, Lat og byen. Eller er den lange, lat beregnes fra byen?
    Hvordan har har du dine indstillinger?
    Hi
    It works again, it is a while ago that it worked again.
    I think that you should just write the name of the nearest large town.
    Here's what Fibaro wrote:
    Piotr Wardęcki
    The problem is on the Yahoo site. The weather has not been shown correctly. Try to change location to some bigger town (if applicable). This problem appears from time to time in some regions only. If you cannot fix it by changing location, just wait. It will be corrected.
    Sorry for inconvenience
