Send whatsapp from scene
i am trying to send multiple whatsap from scene. I can get the scene to send me 1 whatsapp, but not more tan that.
This is my code. Am i using the wrong funtion to call the http page? Have this running on raspberry pi. Just open the link and the pi sends a whatsapp to my phone.
7 answers to this question
Guest reiniertc
hi Patrick,
I'm not sure that Whatsapp will work like you would.
I've tried it and it worked, but it broke again becaouse of whatsapp user license violations.
I now use telegram: much easier because they've got a bot-functionality build right in...
    Thanks,that works perfect!
    Hoe do I call the http command in a scène?
    Guest reiniertc
    I've made a setup where the telegram script to send the message is in php on my nas.
    On the fibaro, I use the following procedure:
    1. a variable called telegram_bericht (=telegram payload). This variable contains the message you want to send.
    2. a virtual device with 1 button. When you press the button, the message from telegram_bericht is sent using a GET command on my php script
    This way, I can use the same procedure for sending messages in different scripts.
    the lua code is as follows:
    Lua code in my script that triggers the message:
          fibaro:setGlobal("telegram_bericht", "Televisie%20automatisch%20aangezet");   -- put message in variable telegram_bericht
          fibaro:call(211, "pressButton", "1");  -- send telegram message by pressing button on the virtual device "telegram bericht versturen", in my case deviceno 211.
    Lua code in the virtual device "telegram bericht versturen":
       HC2 = Net.FHttp("192.168.178.12")  -- ip of my nas
       response = HC2:GET('/telegrambot/stuurTelegramBericht.php?bericht='..fibaro:getGlobalValue("telegram_bericht"))
    The php script is pulled from the official telegram documentation. I tweaked it a bit so i can push the message using "?bericht=this%20is%the%20message"
