If device has neighbour green indicator! If not red... Simple! Please add this for devices its so much easier to fix 95% of mesh problems! And helps reduce support calls! Simple and should already exist!!!!!
Do you mean in the web interface?
Sounds like a good idea.
One day I hope we will have more transparency into how the controller is working
1. Visibility into scenes that have run and why triggered
2. Mesh network reporting, as per suggestion above
3. Improved event panel, as per the bugzilla I already raised
4. Improved heating panel with more visibility as to when heating was run, why, for now long, how efficient it was etc etc
5. Integrated scheduling tool... I know this one is about functionality not transparency
I could go on....
