FGK-101 Door/Window sensor only supports one temperature sensor?
Hi!
I connected two DS18B20 sensors to the I²C  1-wire interface of the FGK-101 according to the manual of the universal binary sensor.
But it didn't work - only one connected sensor works ?
I am afraid that won't work. The FGK manual says:
Supported temperature sensors: single, DS18B20
    Hi Peter!
    Thank you for clarification, so I am really sorry because I always read the manuals, but in this case I missed the important thing
    /emoticons/default_icon_redface.gif" alt=":oops:" />
    p.s.
    I²C is gone
    /emoticons/default_icon_cool.gif" alt="8-)" />
    No problem. I can understand that you assumed that the UBS and the FGK would have the same capabilities. And the UBS doesn't run on a battery because it acts as a Z-Wave router. Because of that, it is always active. To be on the safe side: it needs a >= 50 mA, 12 V supply.
    Hi Peter!
    Yeah I read this before, that is a really no go for the UBS, because I need a device that is battery powered.
    So I'll get some more door sensors for measuring the temperature
    /emoticons/default_icon_eek.gif" alt=":shock:" />
