Scene with time and GPS location
I'm a new user with Fibaro and have non experience with creating scenes.
This morning i was trying to create a scene with power off an device at a planned time at 23:00 and adding to turn on when i'm almost arriving at home 5000 meters.
The power on worked fine, but when the scene is trying to turn off it will immediately turn on because i'm at home, how can i solve the power off issue when i'm at home?
14 answers to this question
    Can someone give me an start to get this working?
    please can you describe what you want?
    or show a picture of what you allready have and we can go with that
    im guessing theres a flaw in your logic
    So i guess you want to turn it off indipentently if you are home or not at 11 PM? Then if you left home and then arrive back home, then at 5000m you want to turn it on?
    You need to tell the system if you left home or not. (If you left outside of the 5000m).
    I other word, the Turn on the light scene reaching 5000m can only be triggered if you left outside of this range, otherwise not. (Still home)
    My self got a trigger to 3 global variables, Me, My wife and Home Status. I set the first two depending if we left home or not (Set by range, like you). If both left home (Home status = Noone Home), i turn of all lights etc. When one of us arrives back home i trigger the "Welcome home scene". Turning on lights etc. But only of the Home Status is Noone Home.
    At the end when the door is opened, the wallway lights gets triggered etc.
    Do you use LUA or graphic blocks?
    In any case here an example of LUA code
    Please replace UserID with real ID  (to find out the user ID in the system use
    By the way you don't need to tell the system if you left home. The system is tracking your movement, so  when you'll be more than 5000 meters away and  will be coming back the scene will turn the lights on again.
    When you at home the current and previous distances are both less than 5000, so when you'll turn lights off it will stay off. Please create another scene (or VD) to turn off the light at 23:00.
    If you want to be more sophisticate, you can loop the scene and then you can turn off the lights at 23:00 inside the scene and don't need Location trigger at header.
    I don't use graphic blocks, but I believe you can create the same scenario there as well (w/o debug portion)
    Thanks!
    How often do you poll the GPS position for the users? What about battery drain?
    local homeLoc = "40.7486;-73.9864" --A point is expressed by latitude and longitude. Please fill in your home location
    Nice geographical coordinates
    I use schedule option...
    On expected period of returning home from work (17:00-21:00) I poll GPS every 5 minutes. Same for morning hours (06:30 - 10:00). Between 10:00 to 17:00 every 20 minutes.
    During the night no GPS polling at all.
    Higher poll rate for my wife... monitoring her movement
    I didn't see any major impact on battery consumption.
    Nice! So i Guest the trigger for this scene is upon every poll och the device.
    - What Will be the return if the phone is off? Null?
    - When phone further on was started again does it require the fibaro app to be started? (iPhone)
    When the phone is off there is no trigger....
    Every time that user's phone sends GPS location the scene is triggered.
    Of course the GPS location sends by fibaro application  (iPhone or Android).
    My personal experience shows that android phones have better response.
    Thanks for the LUA script i've tried it building with blocks, how you've learned scripting could you give me some tips to start some interesting sites?
    Since the coding in HC2 is some kind of hybrid between LUA and fibaro functions, may suggestion is to take basic training (on-line) for LUA and Fibaro functions - see links below
     (needs registration - is free)
    Another way to have better understanding what is going on inside HC2, is to create graphic blocks and to switch scene edit mode to LUA based.  Try it on your GPS blocks.
    Good luck.
    Update:
    I have tried this scene now for a while but did notice one issue.
    Ig the polling is set to eg 5 min the polling only occur if the person is moving.
    So it must do a polling withing the 3000m range or it will miss it upon arriving home.
    Is this how it sopose to work?
    The GPS tracking doesn't work as expected. There are a lot of blind spots and delays on location.
    Several cases have been opened, but till now no proper response or support from Fibaro.
    In general the tracking is not stable at all and it works occasionallyץ
