Dear Forum,
how can I set the following parameters at the Relay Switch FGS-222?
  • set ConfigInputBehaviour: FollowSwitchContactClosedONOpenO1
  • set ConfigControlKey2Behaviour: DeviceStatusIsNotChecked
With the FHEM System it is possible to set the double relay in a mode that both Switches are treated as one device which means that only one Switch is visible an when switching allways both are switched.
I guess that These Parameters are not visible and Need to be added. Can somebody in the Forum help?
Thanks in advance!
Best regards,
ArnoNym
