I have serveral Fibaro-eye sensors, but the issue with the lux i can't solve.
when i press the button on the top for signal it works and get lux eg 270 or 30. But after a while it doesn't work.
I have to pres the button again!
what can i do
You shoud adjust parameter which says "how much light intensity has to change before new data will be sent to HC2".  As default it is 200LUX, you should make it smaller for better LUX reading, eg. 50LUX.
    Some are replaced bij 50 and 10 already
    No luck there.
    Reported as bug 2762. Workaround published by Fibaro:
    "For now you can disable reports on lux change (parameter 40 = 0) or set it to value greater than 100 lux and turn on frequently automatic reports (parameter 42) -> for example once for 2 minutes. If you had parameter 40 on low value (<50) it won't affect your battery life (or impact will be minimal)."
