dynek 0
Hello All,
I'm trying to create a scene with "details" configured straight away but I can't seem to succeed.
curl -v -X POST -d '{"name":"My Scene","enabled":true,"isLua":true,"lua":"local test=\"test\";"}' "
This create a scene without any lua code inside and when I edit it, I see graphic blocks options.
If I do the same request but to update it, so PUT and mention the ID, lua is correctly populated.
Is it possible to do so or would I have to first create an empty scene and update it right away ?
Thank you
