How to control a Arduino Nano with ENC28J60 from HC2 ?
Guest samuelboerhoop
How to control from the HC2 (fibaro) by means of a VD an arduino nano with ENC28J60 ethernet module?
With other words: I would like to sent commands to an arduino nano with an ENC28J60 to control a relay and/or to read inputs status or analog inputs from the arduino nano to the HC2 (including arduino code)
Your idea's would be appreciated
Thanks a lot
Hi there, did you get a reply from this?
If not, have a look at this as an option
// web host - assume it's on port 80
ArduinoHost = Net.FHttp("YourIpAddressHere","80")
// take slider value range of 0-100 and map to 255 (i.e. multiply by 2.55)
mySliderValue = math.floor(_sliderValue_ * 2.55)
/use HTTP Get to Host - uses parameter on URL and a derived value from UI
ArduinoHost:GET("/DoSomethingWithParameter?R=" .. mySliderValue )
i got it working like this in a VD button:
fibaro:log("Connecting...");
local selfId = fibaro:getSelfId();
local ip = fibaro:get(selfId, 'IPAddress');
local port = fibaro:get(selfId, 'TCPPort');
NANO = Net.FHttp(ip, port)
response, status, errorCode = NANO:GET('/?relay2on')
fibaro:sleep(600)
if ( errorCode == 0 )
then
  fibaro:log("Transfer OK");
else
  fibaro:log("Transfer Failed");
thanks
Have you considered using a z-uno (
instead? This is a very cool device, basically an arduino with z-wave chip/capabilities integrated. Can be configured for in total 10 z-wave devices (sensors, actors, etc). Works like a charm on Fibaro, and easy to set-up / configure if you are already used to arduino.
Best, Rene.
