I've an HC2 with lastest stable firmware.
I have a big problem with scheduled activites like "turn on light every day at a specific time" because this kind of scheduling works properly for 2/4 days then it stop ti work and the only way to solve temporary is HC2 restart.
Any suggestions or similar problems?
Yes, I do have a similar problem since ever. The only difference is, that my scene NEVER works, not even for one day.
    Have you flagged "Start when Home Center 2 start" and reboot?
    At the beginning I got your same issue solved with this option.
    But after few days stop working
    What version are you running? Is it just scenes or does the z-wave engine freeze completely? Can you turn things on or off from the Webpage?
    Version : 4.056
    Only automatic scenes stop to work.
    Devices continue to work properly.
    Problem solved.
    The problem is due to same start time of all devices.
    Example:
    Scheduling: every day at 5 PM
    Device group: 3 lights devices
    Action: turn on 0 sec
    Workaround:
    Introduce late start time for every devices
    Example:
    Action:
    turn on 0 sec device 1
    turn on 20 sec device 2
    turn on 30 sec device 3
