maxdreamland 1
I was wondering how the lifecycle of a scene is that is tagged as an %%autostart scene?
I noticed for example that it is started immediately after saving the scene, and i would assume that it is also started after the system reboots...please correct me if i'm wrong.
what I'm not sure about is what happens when i save the scene a second time (or a third time, or a fourth...). I can see that it is in fact run again after each save, but what happens to the already running instance? since autostart scenes are often used for doing things in intervals they often run in an infinite loop. so what happens to such an already running instance when i edit and save the scene and it is started again?
by the way, i assume that the number of parallel instances allowed is set to 1 if that would make a difference for the behaviour.
in this context I also wanted to ask about the "Deactivate" Button on the very bottom of the "Advanced" tab of a scene. As far as I understand it it should kill all instances of the scene...or is it all instances of all scenes?
and why do i get an "access forbidden" whenever i try to click on this "Deactivate" button? (my Alarm is not armed)
thanks in advance!
best regards
Max
10 answers to this question
