Alarm Panel - How do you get 'Push Message' to work?????
I have started to try to use my HC2 as 'Alarm central' for my house. Most certainly far from a good system
/emoticons/default_icon_curve.gif" alt=":-/" /> but I thought it was a nice additional feature to use in the HC2.
Have tested it for some time now and think that it is working rather good. But it is one feature that I want that I simply can´t get to work.
It works good to Arm and Disarm the system (using the iPhone App) and if I intentionally triggers the alarm when it is in Arm state (i.e. opens a door), the system turns on my sirens, turn on a lot of lights in the house and send me an e-mail. But I also want to have a "Push" message from the system to my iPhone but that does not seam to work?
In the Alarm Panel it is predefined 'Actions' and one of them is "Notification" but as far as I can see from my test it only sends e-mail. How do I do so that it also sends "Push" messages and also perhaps "SMS"?
Anyone have a solution for this??
Hi
Configuration - access control - device list at the bottom of the page, here you can tick for your phone etc.
You must have already defined an "alarm" notification.
See picture.
Hope it can help.
using push you need correct device ID's for the phones too if you want to specify, so use ..
.. to narrow down the search
Cheers,
al.
