Hello , I have a problem .
I have 2 RGBW and I need one algorithm in LUA that makes same color for both  . (When one is on ,the other one start on with the same color)
I have done this for the moment:
if (
 ( tonumber(fibaro:getValue(167, "sceneActivation")) == 26 )
or
then
 fibaro:call(111, "turnOn");
 fibaro:call(8, "turnOn");
I'm sorry for my bad english ,I'm a begginer
    It works...but with this Lua algorithm when i change a color the other one is changing only if a run again the scene
    Did you change this line:
    20 color
    it should have the same number as the id_master
