Secure SRT-321 termostat timer
Hi!
Can someone tell me if it is possible to disable the timer that starts when you adjust the temperature manually? If I adjust the temperature I always want it to keep that temperature until the heating panel tells it otherwise. Is this possible?
Regards
Are you adjusting the temperature for the SRT-321 thermostat on the physical device using the wheel - or are you changing the temperature via the Fibaro app or GUI?
    Hey!
    If I change temperature in the GUI it will count down from 2 hours. If I turn the wheel on the device it will count down from 2 hours and 15 minutes.
