Hello
I have a Fibaro Door Sensor , one Month ago it started to tell me that the battery is low.
So yesterday I changed the battery , after the change the Led keep Blinking all the time even that in Fibaro the Module is reporting correctly if the door is open or closed.
What is that problem. ?
Before the battery change there was no problem.
I am on the last Beta firmware with my HC2.
When I changed the battery the door was open.
I hope somebody could help me out
Is the tamper at the back depressed fully? some of my sensors blink when opened / closed because the sticky tab doesn't pull them far enough to the door, making the tamper not quite pressed in...
I can't help you, but I had a similar experience yesterday. I included an (old) FGK-101. I appeared in the web interface. Then I noticed that the LED was still pulsing. I thought, well, It will stop anyway, either after some time-out or because the battery has run out
/emoticons/default_icon_smile.gif" alt=":-)" /> so 'll check later. Of course I forgot and several hours later it was still blinking. I excluded, reset and included again and it's OK now...
    Maybe I will try to reset the damn thing and see if it stop blinking .
    The back temper should be good as it was working before and I didn't changed anything ( but will check that also
