Question: Check if table value exist and contains content
I try to read a json value but it is not always present in the response.
The Problem is that it always ends in : [ERROR] 20:13:07: line getSelfId();..."]:16
Is there another solution for the way to check the response code?
Thanks for your help! I try to learn fast to give something back
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> --
-- if requestcode is empty set it to 404
if requestcode == "" then
    requestcode = 404;
-- I need to know here if result[1] contains playerid
-- empty request would look like: {"id":1,"jsonrpc":"2.0","result":[]}
-- Positive request looks like: {"id":1,"jsonrpc":"2.0","result":[{"playerid":0,"type":"audio"}]} or {"id":1,"jsonrpc":"2.0","result":[{"playerid":1,"type":"video"}]}
if resp_decode.result[1].playerid then
local playerid = resp_decode.result[1].playerid;
