Hi there,
I have purchased two Fibaro Dimmer 2 units and connected each unit to a set of Philips instyle Attilio dimmable LED lights.
One dimmer is connected to a set of 3 lights, the other one two a set of 2 lights. Each light consumes 7.5 watt max.
For about two years I have used these lights with just an on/off switch. After installation I found that the lights maximum brightness is far lower than before.
I have forced the calibration of the dimmer several times with no luck, tried with and without the bypass 2 installed and both calibration options as well, nothing changes. As well as forced leading edge / trailing edge dimming. I hope anyway can help me with a suggestion, I really would get the full brightness with dimming capability back.
Thanks,
Hans
    never mind. it must have been just my imagination. i connected it back to the switch and measured the light with a professional photography. the amount of light is exactly same.
