What's up with remote access? Anything?
Hi All,
Since I've upgraded to iOS9.0 I've noticed I cannot get any remote access at all on my phone through to my HC2.
Not only that but every time I access home.fibaro.com it finds my account but continually says my box is 'offline'.....which it isn't!
Any help appreciated as remote access is rather important to me!
KR, Dave:)
hello!
I have the same issue as you have. My solutions was to have a VPN server home. So now I switch vpn on my iphone and that always work with the fibaro app. Then I dont have to relie on the remote acces of fibaro.
regards K
I’m on IOS9 and remote access works, but not all the time. VPN access is much faster and almost 100% reliable, not mentioning comfortable administration over the browser from remote (home.fibaro.com is extremely slow to do anything with HC remotely).
I use VPN too... It feels like home
What vpn server are you guys running? Im no network guru so what is the easiest solution?
My setup is following - home NAS QNAP T110 (using it as a media server with all media stored in it). It has a VPN build in, you just need to set it up (it’s easy for non IT guy as well with a little of googling). Its running 24/7 for more than  years and can provide also other useful features (download station, surveillance station, DLNA server, time machine…)
I use My Synology ds1815+ online 24:7
I use a standalone OSX server for Php, hosting, VPN etc
I've got OpenVPN in my flashed OpenWRT (it's like DD-WRT) modem/router.
    Hi Guys,
    Thx for replies. So do we actually know what the issue is?? Never used to have problems (not that I recall anyway). I did go from ios7 to ios9 so not sure if that has anything to do with it?
    Anyhow....I was looking to get a QNAP for my Mobotix T25....do they all have VPN built in? Was looking at DS215J
    KR, Dave:)
    Hi All,
    Just thought I would update you. A reboot fixed the problem. Unsure what problem was....maybe Fibaro did some maintenance at some stage and it needed to reconnect. Either way, working again now thank god.
    KR, Dave
