When not equal operator in block scene ?
Hi All
When Fibaro will implement the not equal operator in block scene ? I have a variable with multi values and I would like my scene start when it is not equal to one of these values so instead of using not equal symbol, I have to check if it is equal to one of my 3 other values. Is it so complicated to implement not equal ?
8 answers to this question
Hi All
Hi
Version 4.061 has the function.
It would be really good if you could put the values of variables in the field where it is written "35" on the picture.
Fibaro?
    ok thanks for your reply..
    It's a good news but you mean it is not possible to enter a value as on your screenshot... with which value you can do the comparison if you can't enter a value ?
    Guest chaicka
    Maybe hTiger1 means putting a variable instead of a static value so that other scenes can be written value to a variable (or global variable) and this scene pulls the value from that variable.
    I think you're right...however, it's a very good idea
    Hi
    /public/style_images/master/attachicon.gif" alt="attachicon.gif" />
    Fibaro?
    I created a scene but the operator is not available with variable !!!  only =, <, >.... why, it's a mystery !!!
    Hi
    It depends what is being shown in the box.
    About it is a
    1 Variable
    2 Predefined variable
    3 Units
    I would like to add a AND condition to the attached block scene
    I have following conditions today:
    IF (time = t1) OR (time = t2) OR (time = t3) OR (time = t4) THEN heating = ON
    and I would like
    IF ((time = t1) OR (time = t2) OR (time = t3) OR (time = t4)) AND (house_status <> "on hollydays") THEN heating = ON
    I don't know how I can add parenthesis for the Or group and add the AND condition with NOT EQUAL operator.
    I think I have to convert my block scene in a LUA scene just because NOT EQUAL condition that doesn't exist for variable and because parenthesis can't be added
    So I think this lack of operator and parenthesis manipulation is very frustrating and is complicating something that could be easy to do with block
    I'm right to convert it in LUA ?
    thanks
    up...
    no news for this functionality !!!
    I would like to use 'not equal' for predefined variables
