Scene for FGD211 once tripple click - LUA code
I have some questions how I can add a scene when I tripple click of the FGD211. The parameter 41 is set to 1. So far so good.
First question: Are there anything else I need to do, before I activate the parameter to the FGD211? I red that someone needed to add new device (the same device, tripple click), to get this feature up and running? He did get a new cihild device, but I dont get that. It just says "wake up device inorder to..." when I add the new device.
This is how my LUA code looks like:
The device ID is 13, and I want to turn off device 8 and 10 once I press the monostable switch three times. I should mention that Im not sure if I should use the value 25 or 15, since I cant rememeber how I put the cables (S1 or S2) but I need to know if this is how if the code in general is wrong?
%% properties
13 value
%% globals
if (
 ( tonumber(fibaro:getValue(13, "value")) == 25 )
or
then
fibaro:call(8, "turnOff");
fibaro:call(10, "turnOff");
