is there a easier way to increase light every 5 min with 5% value
for now i have :
local sunrise   = fibaro:getValue(1, "sunriseHour")
local sunset     = fibaro:getValue(1, "sunsetHour")
local time75     =  os.date("%H:%M", os.time()+75*60)
local time80     =  os.date("%H:%M", os.time()+80*60)
local time85     =  os.date("%H:%M", os.time()+85*60)
local time90     =  os.date("%H:%M", os.time()+90*60)
if     (((sunset <= time90 and sunset >= time85) or (sunrise <= time90 and sunrise > time85))
       and tonumber(fibaro:getValue(lightItems, "value")) < lampValue05  )
              then fibaro:call(lightItems, "setValue", lampValue05)
                      elseif (((sunset <= time85 and sunset >= time80) or (sunrise <= time85 and sunrise > time80))
                      and tonumber(fibaro:getValue(lightItems, "value")) < lampValue10  )
                             then fibaro:call(lightItems, "setValue", lampValue10)
                                     elseif (((sunset <= time80 and sunset >= time75) or (sunrise <= time80 and sunrise > time75))
                                     and tonumber(fibaro:getValue(lightItems, "value")) < lampValue15  )
                                            then fibaro:call(lightItems, "setValue", lampValue15)
etc....
Don't understand exactly what you want to achieve, but I hope this will help.
If current time >= sunset then the light will increase +5 every 5 minutes, it will stop if light is set to 100
You can also look at this:
    i already achieve a script that allows me to activate the light 1 hour before sunset whit a light sensitive of 5%
    after that it will increase by 5 % evvery 5 min even as time is before sunrise
    only the script is verry long (but it works)
    try to simplify the script
    and your script works gread. Thanks
    know a can change the value easier
    Thank you
