HC2 apache server problem
Guest guidetti
Guest guidetti
After a supply crash the HC2 booted normally but I am not anymore able to connect through the browser. Its IP address seems ok and the device answer with "ping".
I tried the recovery mode with both its normal Ip and the default static IP (192.168.181.1 connected to the PC with appropriate IP change in the PC itself) but the HC2 doesn't show any screen like the recovery page on the browser. Ping Ip status is still ok.
After having connected the Fibaro vga to the screen I notice at the end the boot messages in recovery mode the following message:
Fibaro STARPAR: serive(s) returned failure: apache2....FAILED!
Someone has already encountered similar problems?
thanks,
Elio
My HS2 also crashed last night, similar problem, ping's ok, error 503 screen when I try and log in, restarting service brings up the correct login screen, but it will not accept any of my usernames or passwords. Though the 3 leds are lit on the front panel, the Z-Wave led does not light up at all even though devices are active. I've not tried using the vga port.
I have had issues before where the HC2 has crashed, and I've noticed that if it is indicating an upgrade is available, it has brought up the 503 error screen before, but previously restarting the services has solved the problem, not this time though.
BobWinter
