King 1
Hello!
Is there a possibility to set the FGD-212 Dimmer v2 in a standard on/off mode without the slider and dimming function?
I connected a regular motion detector from Steinel (not the one from fibaro) to the FGD-212 Dimmer v2 input. I just want to activate a scene through the Dimmer if motion is detected! There is no lamp etc. connected on the output cause i just need the input signal!
After manual switching to on via the web interface it is automatically switching off after a few seconds??? Is this normal and is there a method to avoid the auto switch-off?
I don't need the slider or dimming function and i'd like to have just the two on and off icons instead of the %-Icons.
Any ideas??
happy new year to all of you!
