I have tried to install a Fibaro Dimmer 211 module in various ways based on diagrams found on internet, but without succes.
As you can see in the attached diagram, I have two switches that switch 2 lamps (only one on the diagram).
Currently my switch has 3 connections: a double brown, a gray and a black wire.
I have shown the other existing wires in the switch box in the diagram (an additional brown, 3 blue and 3 green)
Can anyone tell me how to correctly install the Dimmer 211?
Many thanks in advance,
Sven
This is a very good start, they have diagrams for various setups you should be able to find what you want or adapt for a 3 wire setup.
Edit: And you do have pushbuttons I? It won't work otherwise.
    Thanks Joacim,
    i'll check out the diagrams also.
    i do not have pushbuttons, but I read it should work with switches also?
    I don't think you will be able to dim the light if the buttons aren't monostable or spring loaded. It may work turning it on and off to a pre set value.
