Labtec 1
I have probably a mechanic problem
/emoticons/default_icon_confused.gif" alt=":-?" /> the Danfoss thermostatic valves communicate fine with Fibaro, I can set the temperature in heating plan, and the settings where succesfully send on the right time to the Danfoss thermostatic valves.It seems that the pin inside the Danfoss LC12/13 doesn't open/close the radiator valve enough, so it is too warm/cold in the room.
I use a Fibaro motion sensor for measure the temperature (main temperature sensor in room)
The radiator valves are from Comap so I use an metal adapter 28-30mm (attached file) and I use the Danfoss 30mm plastic adapter ring.
What can I do to use these Danfoss thermostatic valves
