Hello
I want to use my Octan Remote CRC 3-3 to switch on and off the ventilation (button 1 and 2). And want to use button 3 and 4 to increase and decrease the fan speed by a dimmer. The Octan works well only on and off. My gateway is a HC2
Can someone help me.
Make sure parameter 2 has value 2 and dimmer is in association group 7. I have on nodon wall switch (same configuration). If you using scene make sure parameter 2 has value 0 and parameter 3 has value 0.
You can make Lua Scene for that. Value for pressed button 3 is 33 and for pressed button 4 is 44. I haven't done this scene, becouse i can dimm two dimmers with association.
    Thanks so far,
    I read some things I've never heard of. I'll see if how far I come with this information.
    It works, Thanks
