Hi all,
I setup  a raspberry pi with homebridge and also the sonos-http-api server.
Everything is working really great, however, I am a little stuck here:
I would like to call (open) a Url on a VD buttonpress to start the sonos function (especially the TTS).
Format of the URL is quite simple: "
to say"
How can I do this?
cheers
joystick
    Wow, Great! I Will Play around with that tomorrow...
    Thanks a lot, this is getting me on the Track for more!
    I think there might be a Problem with the language mix (english/German ) though.
    If you have set url_lang = "de-de"; in the say.js  and if you have set your HC2 to (in your case) German you should be fine.
    You will need to translate the English sayall words (in my example) to German.
    Everything is working great.
    I found out that the Url encode is also working with "+" instead of "%20" which is more easy to read/Write...
    Cheers
    Joystick
    Yes with the URL Encode it does work fine too.
    So final code will look like this:
    Change the IP 10.0.0.105 accordingly!
    Will be doing some more coding when I have more time.
    Works this code only with a RPI?
    Or - did you realize TTS and Sonos via
    RPI.
