Out of memory /Number of instances of scene has been reduced to high memory usage.
Hi Guy's
I have a problem with a scene , i am on the latest Beta Firmware and I get
Out of memory | Scene: Global Check
What is wrong with this scene ?
Thanks in advance for help
10 answers to this question
Remove "Night" from the GLOBALS header:
By changing the global variable the script want to be called again and again.
Why it says "Out of memory" I don't know right now.
Guest bozman
Hi, could someone explain more regarding the %% globals, when should I have a value there?
I believed that it always should be there if you want to read that value, but maybe fibaro:getGlobalValue is enough?
I have the same problem as FUUSS with memory related issues.
And it's really hard to troubleshot these kind of problems if the limitation in software isn't telling you anything more.
Guest chaicka
I am pretty new to LUA scripting. Based on recent attempts to troubleshoot some scripts I have and writing new ones, it seems with 4.061 or 4.062 firmware, if global-variable is added to the %%globals section, it keeps triggering the scene/script to run whenever that global-variable is changed. I have since removed it and just use fibaro:getGlobalValue and the script works fine so far and also no more "exceed instances" error/alert coming up.
Guest bozman
I tried it quick on a scene firmware 4.062 and if
I use fibaro:getGlobalValue in a if statement and I do not have
that global value in the %%globals it never runs that if statement,
changed it back to have in the %%globals then the if statement works fine.
I can't really understand the logic here.
You only use %%globals if you want a global variable to trigger a scene:
I use it to set my alarm; if the global variable "Sleeping" or 'PresentState" is changed, the scene for arming/disarming devices will be run automatically. if the value is 0 is will disarm devices and if set to 1 it will arm devices.
So if you just want a value of a global variable you don't need it.
top of the Alarm scene:
%% properties
%% globals
Sleeping
PresentState
Guest bozman
Ok so you are saying that in the scene for instance if you have a sundown as global value you never have in that scene
if sundown=yes then
 turn lights on
it's enough to have it in the
%%globals
sundown
and then in the rest of the scene.
lights on
that's it?
You will always have to do the check, because if the global variable is saying no, it still will set the lights on (it acts on the change not on the value).
Scene 1:
%% autostart
%% properties
%% globals
if sundown then
  fibaro:setGlobal("sundown","yes")
elseif sunup then
  fibaro:setGlobal("sundown","no")
Scene 2:
%% properties
%% globals
sundown
if getGlobalValue("sundown") == "yes" then
  lights on
But you will normally only use it if you really want to have a instant trigger on a change, if you want to set the light you can better make a scene checking the global variable with getGlobalValue and have a  while loop (or with settimeout).
Guest bozman
Ok, thanks for that clarification!
    I don't really understand what I have to change now , and why this error comes now , and didn't came before
    You have to remove the word Night just after %%globals.
    What the script does is changing the global variable, but the script is triggered by the change of the variable, so it will come in a loop.
