Hi all,
I'm writing a scene for full automation of windows blinds.
I need to check a value against all the values in a table if it is smaller or not.
So far I have come up with:
local StateAll = { }
  StateAll = { value1, value2, value3, value4, value5, valu6, value7, value8, value9, value10, value11}
local Status1= 0
for i = 1, 11 do
    if value1<= StateAll then
      Status1= Status1+ 1
if Status1== 11 then
    local Trigger1= true
    fibaro:setGlobal('Trigger1', true)
      else
        local Trigger1= false
        fibaro:setGlobal(''Trigger1', false)
I works but I think it is not the proper way to do that check.
Can anyone suggest an easier code?
Thank you
These two are more elegant and generic approaches:
or
    Yes something like this I was looking for.  More elegant
    But the first one returns something like [ERROR] 21:04:01: line 116: '}' expected (to close '{' at line 114) near 'for'
    And the second option also returns a '}' expected to close
    Any thoughts ?
    My bad. Was a "{" inserted somewhere by mistake... functions seem to be working
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> Thank you very much
    A question thou if I may:
    table.sort(StateAll)
    if v < StateAll [1]
    [1] is the step ? meaning if I put 2 will it check only every other value?
    What if I would like to check only against value9, value10 and value11 ?
    Regards
    I'm not sure I understand the question, so I've used my imagination to produce 3 versions. The are build on the work of Brick.
    function isLowerThan(threshold, ...)
    lowest=true
    for _,v in pairs({...}) do
    if v <= threshold then
    lowest=false
    break
    return lowest
    function setTrigger1(threshold, ...)
    if isLowerThan(threshold, ...) then
    fibaro:debug("threshold is lower than any table value.")
    else
    fibaro:debug("Some table value is lower than threshold.")
    fibaro:setGlobal('Trigger1', false)
    setTrigger1(23, 21,24)
    setTrigger1(23, 24,25,26,24) -- any number of arguments!
    values = {21,22,23,24,25,24,21} -- any number of values.
    function isLowerThan(threshold, valueTable, ...)
    lowest=true
    if valueTable[v] <= threshold then
    lowest=false
    break
    return lowest
    -- Arguments: a numerical value to compare with,
    -- a table containing numerical values,
    -- followed by any number of arguments that
    -- function as indexes into the "values" table.
    function setTrigger1(threshold, valueTable, ...)
    if isLowerThan(threshold, valueTable, ...) then
    else
    setTrigger1(23,values, 1,4) -- check element 1 and 4 ("21 and 24")
    setTrigger1(23,values, 4,5) -- check element 4 and 5 ("24 and 25")
    -- Special case: if you do not specify an index to compare with,
    -- the fuction acts as if threshold is lower than any element
    setTrigger1(23,values) -- check element 4 and 5 ("24 and 25")
    wow this is very advanced LUA , for me at least
    To clarify my question: I wanted to be able to also check the table only against certain values from it.
    From the first original example:
    v= your  value to check
    for i=1 , #StateAll do
    m=math.min(StateAll [i],m or StateAll [1])
    if v<
    then    fibaro:setGlobal('Trigger1', true)
    else    fibaro:setGlobal(''Trigger1', false) end
    I found out that if I put i=4 for example it will check v only against value4 to value11.
    But what if I would like to check v only against value1 and value5 for example?  setting i=1,5 doesn't work
    Regards
    No, "for i=1 , 5 do" means "from 1 to 5" - not "1 and 5". If you want to do 1 and 5, you need "solution 3". I'll see if I can make a solution that is easier to understand for you, solution 3 contains "varargs" and that is something you never see on this forum. BTW your original question is "not runnable code". And I always like to test my code, so please give me a minute to convert that into "runnable code".
    v=23 -- your value to check
    StateAll={21,22,23,24,25,24,21}
    -- StateAll={ value1, value2, value3, value4, value5, valu6, value7, value8, value9, value10, value11}
    -- A table containing the indices of the values you want to check...
    -- So 1 means "value1" and 2 means "value2" and so on.
    check={1,5}
    for _,i in ipairs(check) do
    m=math.min(StateAll, m or StateAll)
    if v<m
    else fibaro:setGlobal('Trigger1', false) end
    Ah i understand
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />  will test this soon:) Thank you
    I did check and is working. sort of.
    Point is that all the LUA codes with the "math.min" work as soon as i save the scene, but after some time like 1-2 hours they start to return the same number - like they get stuck somewhere.
    But the LUA with table.sort and just checking against the first value from the sorted table works as expected without getting stuck.
    weird.
    Regards
    check={1,5}
    m=nil -- without this, m retains value if you loop this code
    if v<m
    HI Peter,
    I made this script  -runnable this time -  based on some examples from this forum.
    What the script does: it checks the status of different kind of sensors in the house and stores the result in some tables, with the device id and value of the sensor.
    There is also a table with the device id and the last status change.
    From the debug it seems to be working.
    What I would like now is to be able to find out the smallest value from the FibaroMotionSensorsState table.  I will create after tables for the state of the other sensor types.
    Also the scene seems to be kinda slow... I wonder what impact would it have on HC2 if I run it every 3 minutes.
    Could you test it please?
    Regards
    %% properties
    %% globals
       FibaroMotionSensors = {}
       FibaroMotionSensorsState = {}
       FibaroDoorSensors = {}
       UBSMotionSensor = {}
       for i = 0, 300 do
          if   fibaro:getType(i) == 'com.fibaro.doorSensor' then
             value = fibaro:getValue(i, 'value')
             model = fibaro:getType(i)
             FibaroDoorSensors = value
             --FibaroMotionSensors = model
        else
        if  fibaro:getType(i) == 'com.fibaro.FGMS001' then
             FibaroMotionSensors = value
             FibaroMotionSensorsState =  tonumber(os.time() - fibaro:getModificationTime(i, 'value'))
          else
         if  fibaro:getType(i) == 'com.fibaro.motionSensor' then
             UBSMotionSensor = value
    for k, v in pairs(FibaroMotionSensors) do
      fibaro:debug("Motion Sensor Device ID:  "..k.."  Device Value : "..v)
    for k, v in pairs(FibaroMotionSensorsState) do
      fibaro:debug("Motion Sensor State Device ID:  "..k.."  Device Value : "..v)
    for k, v in pairs(FibaroDoorSensors) do
      fibaro:debug("Door Sensor Device ID:  "..k.."  Device Value : "..v)
    for k, v in pairs(UBSMotionSensor) do
      fibaro:debug("UBS Motion Sensor Device ID:  "..k.."  Device Value : "..v)
    fibaro:sleep(300*1000)
    I'm not an expert, but was curious what the script would do (I'm affraid I don't know what this is
    /emoticons/default_tongue.png" alt=":P" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />)
    It runs a bit slow in my opinion indeed.
    My output:
    The script -for me at least- opens up a ton of possibilities.
    For example: I can check if last sensor breached was the one in the garage and if so arm all the sensors and close all the blinds.  Also allows me to open all the blinds in the morning if the first sensor breached is the one in my bedroom.
    And anything else where one would check sensor values and/or last modification time.
    when you have a lot of devices it is quite hard to make scenes where you write each sensor all over again. This way you would have all of them in a table
    Ah sound great
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> But I'm not that far with programming
    I take the challenge
    Give me some time...
    thank you:)
    I think I found a way, maybe not the cleanest..  Now the script returns the device ID and state of the last breached sensors in each category. Just a matter of using the data now:)
    %% properties
    %% globals
       FibaroDoorState ={}
       UBSState =  {}
       for i = 0, 500 do
             FibaroDoorState =  tonumber(os.time() - fibaro:getModificationTime(i, 'value'))
        else
          else
             UBSState =  tonumber(os.time() - fibaro:getModificationTime(i, 'value'))
    local FibaroMotionID = next(FibaroMotionSensorsState)
    local FibaroMin = FibaroMotionSensorsState[FibaroMotionID]
        if FibaroMotionSensorsState[k] <= FibaroMin then
            FibaroMotionID, FibaroMin = k, v
    fibaro:debug("Last FibaroMotionSensor breached device ID: "..FibaroMotionID.." and it was "..FibaroMin.." seconds ago")
    local FibaroDoorID = next(FibaroDoorState)
    local DoorMin = FibaroDoorState[FibaroDoorID]
    for k, v in pairs(FibaroDoorState) do
        if FibaroDoorState[k] <= DoorMin then
            FibaroDoorID, DoorMin = k, v
    fibaro:debug("Last FibaroDoor breached device ID: "..FibaroDoorID.." and it was "..DoorMin.." seconds ago")
    local FibaroUBSID = next(UBSState)
    local UBSMin = UBSState[FibaroUBSID]
    for k, v in pairs(UBSState) do
        if UBSState[k] <= UBSMin then
            FibaroUBSID, UBSMin = k, v
    fibaro:debug("Last UBSSensor breached device ID: "..FibaroUBSID.." and it was "..UBSMin.." seconds ago")
    Well... yes, OK! For fun and pleasure, and because I wanted to try out a new debugging technique, I've polished the code a bit. Not meant as criticism. Code is part syntax and part personal style. See comments in the code, they start with PGBR.
    are you kidding me ?
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> your changes made the code run almost 5 seconds faster. That is huge
    And I'm always up for constructive criticism. How else would we learn.
    Besides I'm just a beginner at this; was happy I could make it work lol
    Now that this part is done, do you think it is safe to run it every 2 or 3 minutes ? won't impact the HC2 to much ?
    What if I include all my devices in such tables and try to make scenes that operate all devices of one kind be independent of adding/removing devices ? Would save me quite a bit of work every time I have to reset a device etc..
    Regards
