Use S2 on a dimmer module to control another dimmer module
this is possibly very simple , but i can not get it to work.
I have connected a momentary switch to a dimmer modules S2 terminal and want to control another dimmer that have no manual switch wired into it
Could someone please tell me how ?
Use association in group 2 in the dimmer that has the switch to S2 attached. In association select the second dimmer. I have this setup and it works. Only sometimes S1 switch is unresponsive (known bug).
Frodo, should not be to difficult to use the device with S2 as a triggering device for the other in a block or lua scene. (Wired or not is not really relevant).
    thanks , working now.
