Qubino Flush 1 Relay turns light on and off rapidly
Have a strange behaviour with my Qubino Flush 1 Relay. After installing it when I turn on the lights with the wall switch it will continuously at a rapid rate turn the lights on and off and on again. If I attempt to turn on the lights the HC2 then it will only switch the lights on for a blink of a second and then they will go off again, while the module in HC2 will continue to show as if they are on.
Any ideas what could be wrong? Let me add that these is normal 230V installation, not LED or energy saver lights.
4 answers to this question
    Problem solved. A bit ashamed to admit it, but it was all due to wrong electrical connection. My bad...
    /emoticons/default_icon_redface.gif" alt=":oops:" />
    Are you using a mono or bi-stable button and have you added the corresponding parameter?
    It's a bi-stable button, hence parameter 1 is at its default value of '1'. While HC2 in version 4.056 does not have template for this Qubino module, I added the parameter definition manually and made sure it is set to '1'. No luck
    Guest chaicka
    It happens. I believe the Qubino module has different pin layout sequence compared to Fibaro's.
