Guest theoverriet
I've problems with some very simple scenes. First one is a magic scene that switches on a fan in case humidity is too high. It's so simple but did not work. I changed the scene into a block scene and it worked for a while. Then I had to reconfigure my humidity sensor, had to update the scene and suddenly I couldn't enter the desired humidity level anymore. I set it to 69, click save and it's reset to 0.
The other one that frustrates me is a magic scene. It switches on a light in case another light is switched on. It worked until the day I thought I should try to reach the same behaviour using associations. I played with association in Group 1 but didn't get it to work so I removed the associations. Since then the magic scene does;t work anymore. I softly reconfigured both lights without succes. Emptied my cache, used a different browser, reset the system... No succes. Finally I replaced it by a block scene and that does work.
I'm using the 4.062 Beta.
