Secure srt321 questions
I have 3 Srt321 thermostats that start different pumps to start heating. If I set a temperature manually, it all works as expected. The thermostat is associated with a wallplug.
Now, I need to set a temperature in a graphic block scene. But as soon as I use Set Target level, it does not accept any input. When saved, it turns to 0 again. So,
1. How can I set a target temperature ?
2. How can I set a maximum temperature for this thermostat?
Some HC fw versions have this bug, when you save the value, it is stored correctly, button the screen it displays 0. You can switch to lua to check the value if you have HC2
    Ok, I will check, thank you. Do you also know how I can set a maximum temp that can be set in the Thermometer?
