Hi guys
Wondering if someone can support me a little with wiring for a two gang one way light switch.
I've attached the current working switch but I'm just not sure where they cross.
In the image top left is common which also has a linking wire to bottom right also labelled common.
Top right is 2, bottom middle is 2.
Thank you
    This is dimmer 1 btw
    Pic
