The wonderful Fibaro support
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />¨
Over one week to reply back with an answer clearly stated in the initial support request!
I have another one...
In the newest version of software introduced open limit on the number of instance for a single scene.
So in LUA scene you can not use the following code:
KOD:
if (fibaro:countScenes()>1) then
fibaro:abort();
The maximum number of instance is 10. The number of instances you can change in scene settings (general tab).
LOL
Guest fat
Pathduck I had a similar issue and replaced the LAN cable to the HC2 and it started to work much quicker and more relaibly
Guest chaicka
Isn't that the standard 'machine response' style of Fibaro support?
Hahahaha
Received too many times this kind of response until I don't even want to bother to waste time seeking their technical support. Hmmm...interestingly, those Philippines or India call centers I have experienced are so similar to Fibaro's technical support - "standard SOP scripted response".
At least you get a response...
/emoticons/default_icon_sad.gif" alt=":-(" /> it hast been 6 months and 3 reminders without a reply... Feel like I am on a blacklist...
I get the same problem with browsing on my pc, doesn't matter which browser etc. Will try a different cable and see if it improves.
